Python store input, disconnect input and reconnect input
   1175   2   1
Hi
On object level I am trying to store and disconnect an input, do in the same script some transforms and reconnect the stored input again.
It gives me errors. Is there something I am overlooking?
def test():
    selected = hou.selectedNodes()
    for kees in selected:
        inputs = kees.inputs()
        print (inputs)
        inputs = str("'"+(str(kees.inputs())[30:][:-3])+"'")
        print (inputs)
        kees.setFirstInput(None)
        #do all kind of transformation stuff
        kees.setFirstInput(hou.node(inputs)
Michiel
You can get the input node's path directly and use it instead of getting it using string slice.
def test():
        print (inputs)
        kees.setFirstInput(hou.node(inputs[0].path()))
-J
Edited by jjayakumar - Nov. 9, 2019 10:35:23
Hi -J, that is surprisingly elegant.. Thanks for the help out, greatly appreciated!
