TOPs ROP Geometry Output performance for caching
1570 1 1- art3mis
- 350 posts
- shadesoforange
- 201 posts
Depends on if you're doing you're doing “All Frames in One Batch” or not. If that toggle is on, it will probably have the same performance as the File Cache.
If you have it off, Houdini will send off multiple Work Items at once to render in Background. Therefore using more resources and therefore faster (should be anyway).
So if you're not simulating (All Frames in One Batch) it's faster.
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
