FONT - Text from external file.
2205 3 1- Tobias Steiner
- 101 posts
- toadstorm
- 359 posts
You could use a Python expression to handle this, if you're familiar. Basically you'd add a spare parm to your Font SOP that would point to a text file, and then create a Python expression in the “Text” parameter that would load that file and return its contents, like this:
I'm attaching a little example.
file_path = hou.pwd().parm("file_path").eval() text = "" with open(file_path, 'r') as f: text = f.read() return text
- Tobias Steiner
- 101 posts
toadstorm
You could use a Python expression to handle this, if you're familiar. Basically you'd add a spare parm to your Font SOP that would point to a text file, and then create a Python expression in the “Text” parameter that would load that file and return its contents, like this:file_path = hou.pwd().parm("file_path").eval() text = "" with open(file_path, 'r') as f: text = f.read() return text
Thank you! I will try this out.
- mestela
- 1716 posts
