lcymet
Nov. 23, 2019 17:18:45
Hey Folks,
I'm trying to do some tricky layout in Houdini for some VFX work, and it would be great to be able to layer a plate with a transparency in front at a depth close to camera, and then a background image in the distance with my CG sandwiched in between. Ideally this would respect camera aperture, fit and aspect ratio settings.
I know about the background display option, but I see no way to layer multiple image sequences at a set depth. Do I have to build a tool for this, or is there an available technique I'm not seeing in Houdini?
Laurence
jsmack
Nov. 25, 2019 18:41:17
lcymet
Yes, there is no built-in way to do this. The simplest way is with textured cards parented to the camera.
lcymet
Nov. 27, 2019 16:24:22
Okay, thanks for the heads up.
anon_user_37409885
Nov. 28, 2019 02:55:41
H18 is getting a lot of things right with the camera, i.e. spherical BGs, 2d pan & zoom, and, a Foreground with alpha option would be very welcome and a great addition. Big productivity gains!
jsmack
Nov. 28, 2019 15:33:12
You could build this right now with an HDA in LOPs. It's a perfect usage for defining purpose on primitives.
anon_user_37409885
Nov. 28, 2019 15:46:12
LOPs is definitely v1; the performance is sub-par for animation; simply dropdown a test geometry Crag and it's jerky-as.
