I am getting a fatal error when I try to render from Karma to disk I know that it doesn't create automatically directories so I create it manually even so the problem persists. I am using it on Fedora 30.
Any tips?
Karma fatal error when trying to save to disk
2744 7 0- mzigaib
- 948 posts
- chrism
- 2492 posts
- mzigaib
- 948 posts
- jsmack
- 7759 posts
- mark
- 2591 posts
jsmackThe bug in the switchlightingbsdf should be fixed in the daily build. Please let us know if this persists.
Fur has been rendering fine for me in Karma. There is a bug in the default hairshader though. It's use of the switchlightingbsdf causes a crash. The workaround is to edit the material to remove these ray switches.
- jsmack
- 7759 posts
markthanks Ill give it a shot.jsmackThe bug in the switchlightingbsdf should be fixed in the daily build. Please let us know if this persists.
which build? 307?
Edit:
Seems all good now. Rendering to mplay works great, and the hair shader doesn't crash anymore.
Edited by jsmack - Dec. 4, 2019 01:05:07
- mzigaib
- 948 posts
jsmackmarkthanks Ill give it a shot.jsmackThe bug in the switchlightingbsdf should be fixed in the daily build. Please let us know if this persists.
which build? 307?
Edit:
You can do that? How can you render Karma to Mplay?
- jsmack
- 7759 posts
