Is there any particular reason MacOs licensing is so broken compared to Linux and Windows at the moment. What change in H18?
Some background on the changes would be great, so we can self-fix without relying upon support. Thx!
[SOLVED] MacOS licenseing
125 6 2-
- goat
- 4121 posts
- mattw
- 43 posts
- goat
- 4121 posts
Here's some of the errors:
Launching License Administrator 18.0.306
“Cannot connect to the license server on computer.local”
Reinstall SERVER key
“ERROR: You do not have permission to install entitlements on server ‘computer.local’”
$ sudo launchctl unload /Library/LaunchDaemons/com.sidefx.sesinetd.plist
/Library/LaunchDaemons/com.sidefx.sesinetd.plist: Could not find specified service
Edited by goat - Dec. 4, 2019 20:38:38
- mattw
- 43 posts
The last issue usually occurs when the license server component was not installed. Which makes sense because the first two errors are trying to connect to a server named `.local` which indicates that the license server component was not installed properly.
If that is not the case I would strongly encourage you to contact support so that they can provide you with further assistance.
To answer your original question, OSX specific changes was to no longer strip the `.local` from the hostname when trying to contact the server. Also hkeys UI closer resembles a standard OSX application.
Matt Warner
Software Developer - Licensing
- goat
- 4121 posts
- goat
- 4121 posts
I think there is a bug. With every computer restart, the license server stops working. A reinstall works or running the following works:
EDIT2: found the issue, the permissions were off; for anyone else needing a quick fix:
sudo launchctl load -w /Library/LaunchDaemons/com.sidefx.sesinetd.plist
sudo chmod 644 /Library/LaunchDaemons/com.sidefx.sesinetd.plist
Edited by goat - Dec. 6, 2019 03:17:49
- mattw
- 43 posts
@goat please email support at support@sidefx.com. Make sure to include all relevant details, license diagnostics and any other content to assist support with your case.
Matt Warner
