I've been reading a ton of other forums about this, but most of them are dated and I'm curious if there is an improved way of solving my problem.
I'd like to export an FBX that contains multiple meshes.
However, currently what i'd like to export is all inside a geo container. How can I convert groups to their own objects so that I can then export them as separate meshes inside one FBX file? I'm sure I can do this manually, but let's say I have a ton of groups that are very specific.
Side note, I'm only inquiring about converting groups to objects because that seems to be what I'm reading in other forums about the subject. It sounds like the only way to do this is at object level and possibly by bundling? Is there no simpler way to do this?
Thank you.
