hello
How to get Arnold and Redshift in Houdini together on Linux?
this is important for me
I can't fix this
help please
thanks
Arnold and Redshift
3248 5 2- SMC7192
- 42 posts
- Enivob
- 2531 posts
My guess, is that you have to modify the houdini.env file, located in the Houdini folder of your home documents to point to the correct paths where you have installed each render engine. Consult those forums/documents for support on how to set this value.
I have successfully enabled Renderman and Redshift on the same machine, but I don't use Arnold.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- TwinSnakes007
- 603 posts
- heimlich
- 14 posts
The one thing i noticed (windows, but might apply to linux as well) is that if you are using packages, Arnold needs to be last in the directory, so call it zarnold.json instead of arnold.json. After I made those adjustments the windows version worked fine.
Oliver Hotz
#creator of ODShelfTools for Houdini: https://origamidigital.com/cart/index.php?route=product/category&path=59_63 [origamidigital.com]
- matsnyman
- 38 posts
- Hamilton Meathouse
- 169 posts
I have a similar issue but with Renderman not working when Arnold is installed https://www.sidefx.com/forum/topic/91925/ [www.sidefx.com]
