Looking at this series of tuts. And this one I am having an issue with:
Tutorial 1 - Assets Dept: Build
At the end of this tut, to see the results a Reference LOP is put down to bring in the *.usd file that was saved out.
After this a Set Variant LOP is used to select variants created earlier. (Just two, one of a barrel with lid and the other without).
However, in my setup I only get one variant(whichever one was established as default earlier).
I've gone over the nodes and tut a few times as I am assuming some error on my part, but I can't find anything I did different to cause the issue.
Was wondering if anyone might be able to spot the ‘error’?
Using Indie with daily build 318.
Solaris tut - Sean Lewkiw
1943 2 0- BabaJ
- 2038 posts
- mtucker
- 4438 posts
- BabaJ
- 2038 posts
Thanks mtucker for the suggestion.
I tried changing from /Barrel/BarrelGeo up to just /Barrel with no luck.
However, on the Add Variant(End Block) node I went through all the parameters, setting and re-setting them.
And this seemed to clear everything up - works now.(the variants are available).
When I thought about it, I remembered I initially wired the block wrong to begin with, so it may have bound up some internal setting.
