Just started using TOPs last Friday and I have already hit a wall - the HDA Processor node adds a “hdap_” prefix to every parameter on the HDA. Cannot seem to find an answer to this in Google/forums which is why I'm posting here. My goal is to set up a simple PDG graph that does the following:
1) Open CSV (filepattern)
2) Process CSV (csvinput)
3) Populate parameters on HDA (hdaprocessor)
4) Save out redshift proxy (ropfetch Redshift_ROP)
Currently I'm stuck on step 3. The HDA we are using is a kind of master scene controller that has a lot of parameters and some of the parameters have relative references to each other. For example we have a parameter with the name “curtain” which takes the name of a curtain, this name is then used to look up the corresponding geometry on disk:
$JOB/geo/`chs("curtain")`
Unfortunately this fails because in the HDA Processor this is now a Bad Parameter Reference as it expects
$JOB/geo/`chs("hdap_curtain")`
Many thanks,
David
