Hello all,
I was wondering if there exists any sort of conditional output switch. A switch with more than one output which decides which output to use based on a condition. An example would be I wanted to see if I could output from a solver to one file cache if a switch higher up in the network was set to one input, but then output to a different file cache from the same solver if the switch above was set to a different input.
If anyone knows of a way in which I might be able to go about this, I would greatly appreciate your suggestions.
Thanks,
-instanceid
Conditional output switch?
1652 3 1- instanceid
- 29 posts
- tamte
- 8444 posts
- instanceid
- 29 posts
- instanceid
- 29 posts
