using 18.0.325
I have a curve node,
then facet, a reverse
and attribute wrangle with expressions of:
@P.x = rint(@P.x/2)*2;
@P.z = rint(@P.z/2)*2;
this is to keep polygon in 2x2 grid
after attribute wrangle the polygon disappears, its there on reverse node.
follow Kenny Lamers Guard Tower tutorial. he is using 16.5
polygon disappears after using attribute wrangle
1237 2 1- bobc4d
- 320 posts
- BabaJ
- 2035 posts
Without a hip, hard to say. What are the dimensions of the line before the wrangle?
If the points are less than one unit, all your points will end up as 0 because rint()bring the values to 0(nearest whole number, e.g. 0.9 becomes 0.45, and that is closer to 0 than 1), so it doesn't matter how much you multiply it by - it will remain 0.
- bobc4d
- 320 posts
