mabelzile
Did you try different text files ? Maybe the one you are using contains some bad characters ? You can edit the demo and remove the validation step if you need to. What version are you using ?
Debian GNU/Linux 9.11 (stretch)
Houdini 18.0.355
I tried different methods of creating a text file through the terminal and using the built-in or online text editors (Nano, Sublime, Google Docs) with saving the file with the extension txt or docx or without any extension at all. In all the files that I created, I wrote only two words “Hello, World!”
If you remove the validation check for MIME type data as text/plain, I get the following error.
ERROR
File "/opt/hfs18.0.355/houdini/python2.7libs/viewerstate/utils.py", line 1147, in wrapper
return func(*args,**kwargs)
File "/opt/hfs18.0.355/houdini/python2.7libs/viewerstate/interface.py", line 278, in onDragTest
return state.onDragTest(kwargs["args"])
File "opdef:/Object/state_dragdrop_demo?ViewerStateModule", line 48, in onDragTest
File "/opt/hfs18.0.355/python/lib/python2.7/genericpath.py", line 37, in isfile
st = os.stat(path)
TypeError: coercing to Unicode: need string or buffer, NoneType found
