Hi there! I'd like to build a level by using Brushes and then select them from World Outliner as input for HDA.
But the problem is: I need to convert BSP to static meshes every time. But I would to have a realtime edit functionality.
What you can advise me please?
Thank you in advance!
UE4 PSB Brush to Houdini Engine Asset?
2244 1 2- vyudin
- 77 posts
- starkium
- 5 posts
vyudin
But the problem is: I need to convert BSP to static meshes every time. But I would to have a real time edit functionality.
Just stumbled upon this looking for the same answer. Did you ever figure out what you can do with this? Or have you moved onto a different solution?
Something tells me it wouldn't be impossible to pass this to houdini. You can work with splines already so there's some sort of foundation for this around.
Win 10 Pro | RTX 2070 Super | AMD Ryzen 9 3950x, 16 cores @4.2Ghz | 128 GB DDR4 CORSAIR Vengeance @3600Mhz | ASUS ROG X570 Crosshair VIII Hero (Wi-Fi) | 2TB CORSAIR Force MP600 PCI-E Gen 4.0 |
