One of the things that is a bit of a drag when tinkering with assets (especially in experimental or refactoring phases or updates on naming conventions)is to update the subnet/HDA parameters to reflect necessary changes on parameter interfaces inside the asset.
I have usually a bunch of Wrangles inside with their own parameters that are then imported on the subnet/HDA(copied&linked) , but as the design changes I have to keep deleting these already imported parameters and redo the import. What's the best way to deal with such?
I was wondering if there is already some standard way of:
- Syncing them?
- Script the import (importing automatically creates a ref link) ? Did not find a method in hou, although the pieces for me to do it myself are there with parmTemplateGroup(), etc.
Sync parameters?
1024 2 0- probiner
- 337 posts
- tamte
- 8526 posts
you can have a look at import blocks if that fits your needs
https://www.sidefx.com/docs/houdini/ref/windows/optype.html#importblocks [www.sidefx.com]
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- probiner
- 337 posts
