hey guys I'm trying to do a person stepping on a sponge and I believe vellum is the best way to do this but im not 100% sure if im correct or even how to do it. any help is much appreciated
thanks
how to create memory foam effect with vellum solver?
2359 4 0- joshwaDrury
- 10 posts
- Enivob
- 2534 posts
Basically you would create geometry in two states. One is deformed and the other is not. Once you have that, you can use a BlendShapes node to cross-fade between them. Add a little bounce using keyframes or CHOPs on the cross-fade control.
To make the deformed state, you could try the the technique in this video. (not vellum).
https://vimeo.com/40157341 [vimeo.com]
Edited by Enivob - Feb. 5, 2020 09:27:41
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- joshwaDrury
- 10 posts
- mestela
- 1737 posts
Here's a simple vellum setup. The cloth constraints make the mattress surface act like cloth, obvriously, the struts give it internal strength and a bit of fake pressure, so pushing down on one end will make it bulge elsewhere.
To get the memory foam effect I used ‘damping ratio’ on the bend and stretch sections of the cloth constraints. Higher numbers will make it restore to the original state even more slowly.
- Enivob
- 2534 posts
