changes to python API in houdini 18?
   2023   4   4
I'm trying to update a drag-and-drop python script I made for importing fbx and obj nodes in Houdini 17, that stopped working after I upgraded to Houdini 18.
So far, I've found, that part of the problem is, that the basic input seems to have changed.
Previously, when I executed the code:
def dropAccept(filelist):
	for file in filelist:
		print (str(file))
I got a string, that represented the file path.
Now, the path string has the prefix: file:///
Is there a reason for this? Should I just remove the first 8 characters of the string, to get the file node to work, or is there a smarter way to do this?
Thanks in advance.
Ivan
Edited by ivanmalek - Feb. 14, 2020 10:02:15
Yes, the same question interests. The drag and drop script that I created in the script folder as externaldragdrop.py stopped working.
I have reported this a while ago as a bug and its in the system (H17.5 also allowed for multiple files to be dropped, whereas its limited to 1 in H18)
Oliver Hotz
#creator of ODShelfTools for Houdini: https://origamidigital.com/cart/index.php?route=product/category&path=59_63 [origamidigital.com]
It definitely needs to be fixed in H18
I just realized we are limited to 1 in H18, any workaround?
