Hey all,
I keep getting these warnings when I launch Houdini. I've even tried a wipe and fresh install and the errors persist. Any tips?
PDG Type Registry: Failed to import duplicate module ‘houdini’ which was previously imported from ‘C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\houdini’
PDG Type Registry: Failed to import duplicate module ‘partitioners’ which was previously imported from ‘C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\partitioners’
PDG Type Registry: Failed to import duplicate module ‘schedulers’ which was previously imported from ‘C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\schedulers’
PDG Type Registry: Failed to import duplicate module ‘utils’ which was previously imported from ‘C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\utils’
PDG Launch Warnings in H18.0.391
1449 3 0- Tobias Steiner
- 101 posts
- Tobias Steiner
- 101 posts
- Pixel8d
- 41 posts
There’s other threads about this. I’ve even posted about these Console messages appearing since v .391 and .416.
https://www.sidefx.com/forum/topic/72515/#post-309230 [www.sidefx.com]
I do not have a specific answer to resolving the issue although mine did go away while experimenting with the env file. There are other suggestions too in different threads I came across (do a search) but did not work for me while it did for other users. Unfortunately I have not seen anything official from Houdini/SideFX staff.
One thing I do notice in the warnings you have is there are different backslashes used throughout the paths like I had. Are you on Windows, MAC, or Linux? I am on Windows 10.
Edited by Pixel8d - April 26, 2020 14:09:04
H Indie | LightWave | ZBrush | Clarisse iFX | HDR Light Studio Pro | RenderMan
- jsmack
- 7755 posts
This is usually caused by the Houdini install folder appearing in the $HOUDINI_PATH more than once. Remember ‘&’ is short for default HOUDINI_PATH which includes the install (HFS) folder.
Double check your houdini.env to see that you haven't done something like this:
which will insert the houdini root folder twice.
HOUDINI_PATH = "/my_plugin1;&" HOUDINI_PATH = "$HOUDINI_PATH;/myplugin2;&"
