Is there a way to refer to a dops field at a specific frame?
For example, “The ”ty“ position at frame 120 of obj0”
I tried playing with the “record number” field in the dopfield command but unless
I am misunderstanding, that does not refer to the frame number:
dopfield(“/obj/dopnet1”, “obj0”, “Position”, “Options”, 0, “ty”)
I am sure I am missing something simple or the correct command.
Thanks,
avid
Dops Question: Dopfield
3021 2 1- davidmarcus
- 153 posts
- pbowmar
- 7024 posts
Hey there!
I'm not sure how you'd do it with an expression, but you could use the Dynamics CHOP to cache your data then use the chopf() expression to get the data on the frame you wanted. This might be safer too, since you could write the cached data to disk and not risk a recook of your DOPs sim.
Peter B
Peter B
- mtucker
- 4419 posts
