Hi there, im trying to archieve something like this:
https://i.imgur.com/e8cdsDL.png [i.imgur.com]
I had 2 ideas that didnt worked out, or i became stuck. Especially on the second one.
1)
Scatter points on the surface, and then Copy meshes to the points for a Boolean. But then the hand as no thickness. And its not really procedural, since all the holes would look kind of the same, if i dont create like 10-20 meshes.
2)
Scatter Points on the Surface, and use a voronoi fracture, and then somehow deleting some of the fractures. But im not really sure how to get that done procedurall.
I bet there is a quite easy way to do this, but my Houdini knowledge isnt good enough yet.
I would really appreciate any kind of help. Thanks!
How would i go about creating that effect procedurally?
2032 5 0- Lucaroe
- 16 posts
- jsmack
- 7754 posts
- Aizatulin
- 474 posts
here are some experiments using voronoi fracture.
rough ideas:
There are many possible modification. Here is a file, which seems to work in some cases, but there are probably cases, where
this method will fail.
rough ideas:
- use boolean on geometry with a pushed/extruded duplicate
- use voronoi fracture with scattered points
- get normal/point information from voronoi output and extrude pieces
- use boolean again and subtract pieces from geometry
- subdivide …
- Lucaroe
- 16 posts
Aizatulin
rough ideas:
- subdivide …
Hi Aizatulin, thats insanely helpfull! Thanks so much. It looks really complex, especially sine i have no clue of vex yet. But thanks so much for your time!
- Island
- 340 posts
- Aizatulin
- 474 posts
