When I load an object with the “File Merge” node, it loads a duplicate of the polygons of the object I want to load because the second input field of the “Merge Range” is set to “2”.
I took me a while to figure why the duplicate object suddenly appeared in my simulation. I suspect most people want to load a single copy of their object.
Is this the default setting ? Or did I accidentally change that somewhere. And in case it's default, is there a good reason why is this set to “2” ?
Maybe a good idea to change that to “1” ?
R.
File merge loading duplicate object
695 0 1- toonafish
- 406 posts
