How does @pscale affect in simulation?
   881   1   1
I've been practicing random procedural modeling examples, sometimes with a little use of POPs. I know @pscale defines the radius of particles but this concept confuses me by its function in some sims. Sometimes a sim works fine without defining any @pscale and sometimes not for other sims. I know the question is a bit vague but I don't know how to even start… I hope these two hip files can clarify enough what I wonder.
In sticky_objects_v0.hip there's no pscale setup but works without any problem and in rope_dynamics.hip the sim doesn't work properly if there's not appropriate @pscale setup. I think these two examples are similar since the former uses pointdeform sop with pop grains and the latter uses wiredeform sop with pop grains.
rope_dynamics.hipnc (315.7 KB)
sticky_objects_v0.hipnc (604.3 KB)
If @pscale is not provided, it defaults to constant value. When you supply it, you are overriding that value.
Using Houdini Indie 20.0
Ubuntu 64GB Ryzen 16 core.
nVidia 3050RTX 8BG RAM.
