My salutations;
I'm working on a small compositing project with Houdini Composite.
I have separated some objects by setting specific channels that were exported into an OpenEXR file.
I'm going to use this objects in After Affects, so I'd like to save all this objects into the same file by assigning each object to one layer with a format that supports layers (PSD, EXR, etc.) so I can avoid having to many files.
As you can see in the attached image, I want to export the result of each node in pink, to a layer in the output file.
In this example, the final file will have 5 layers named respectively (Layer_01, …, Layer_05).
So I'm wondering if is there a way to achieve this using Houdini COP nodes in a practical and fast way.
Thanks for putting the time to read this post.
I appreciate your help.
COP: Export specific nodes into layers in the same file
3086 2 1- Abdelkrim
- 11 posts
- anon_user_40689665
- 648 posts
- Abdelkrim
- 11 posts
