Packages expression syntax
   1211   3   1
Hi guys,
I've been trying to get expressions in packages working, but I've come to a dead end.
Here is a snippet of what I'm trying to do :
    "env": [
            "MYPROJECT_PATH":
                    { "$houdini_dev == '0'" : "/global/path" },
                    { "$houdini_dev == '1'" : "/dev/path" }
            "TOOLS_PATH": "/my/other/path"
In my houdini.env, I have a houdini_dev variable that I want to use to switch between the global project and a local project.
But this doesn't seem to work.
If I check the environment variables in Python once Houdini is loaded, I can see my houdini_dev variable, as well as TOOLS_PATH but MYPROJECT_PATH is not there.
What am I doing wrong here ?
Thanks a lot,
Julien
VFX Supervisor @ MPC London
houdini.env is processed after all packages have been loaded by Houdini. Your env vars should be set outside your houdini.env directly in your environment before launching Houdini.
I see, thanks!
One thing I tried though what to put that houdini_env in the package itself, it didn't work either …
Problem is, I can't put it in my env.csh, but that's a problem I'll have to solve somewhere else …
Sorry, I'm not sure to understand “One thing I tried though what to put that houdini_env in the package itself, it didn't work either …”
You could also consider package_path for dynamic package settings. Here's an interesting video about packages and package_path in particular.
https://learncreategame.com/techart/houdini-environment-setup/ [learncreategame.com]
