Adriano
Aug. 9, 2020 18:56:41
I'm trying to figure out how to create a trail behind an animated set of points that is evaluated by travelled distance and not by time. So no matter at what speed my points are animated at they leave a trail of point that has a constant distance between each point in the trail.
Thanks in advance.
A.
mestela
Aug. 9, 2020 20:13:05
generate the trail by usual methods, resample sop it with the distance you want?
Adriano
Aug. 9, 2020 20:40:40
Thanks Matt, yes i did that eventually, but i'm using the “resample by polygon edge” to keep my corners clean (those are paths with hard turns / corners), and when using that option i can't really decrease the amount of samples as much as i want, it sticks to a minimum that is quite dense. But in the end i just accepted the amount of trail points it gave me, then grouped by range to grab 1 out of 2 points on those trails and deleted those to get a lower sampled paths / lines. It works, but the grouping and deleting is a bit slow to playback.
I was hoping there would be a way to just evaluate the distance traveled by my points, and just create a new point behind each time it traveled let's say 0.1 unit, that in wrangle of course, or a simple vex line in the trail sop length parameter.
A.
jsmack
Aug. 10, 2020 13:39:47
Adriano
A.
It's possible to leave points in a trail by distance using a solver instead of trail, however the precision will be limited to the sampling frequency of the solver. In the solver an odometer attribute would be used, and each time the odometer passes a certain threshold, a point would be added. However it would only be when the distance is greater than a threshold, not when it hits an exact value. It might be possible to correct for the overshoot by using the velocity correct for it, but then it might have to handle adding points early, etc.
