Hi there,
I'm hoping someone might be able to help me with an expression issue I'm having.
I want to use the numberical index value from a list of paramters inputs in an expression. Specifically on the blendshapes node, so that it will turn each blend shape on one by one on each frame.
I was hoping there would be something similar to the opdigits command, but I can't seem to find one anywhere.
I am hoping I could write an expression along the lines of if($F == *parameterIndex*, 1, 0) - but I can't find a good way to call the paramter index… Is this possible?
Thanks very much,
Expression Help! Getting the parameter index number...
1135 2 0- dickonknowles
- 9 posts
- mrCatfish
- 731 posts
- dickonknowles
- 9 posts
mrCatfish
First parm1: $F==1
Second parm2: chf(“parm1”,$F+1)
Second parm2: chf(“parm1”,$F+2)
etc
Hi Sean,
Thanks for the reply, can you think of a way to avoid having to manually increase the value that follows $F? For what I am doing I will likely need to copy the expression into many paramter channels, so was hoping to find a way to call the paramter index within the expression to avoid having to increment the value myself.
