using string to name an attribute? SOLVED
   2115   3   0
Hi!
I made a string variable that allow me to choose a name in the channel.
string myAttName = chs("my_attribute_name");
How can I use that string to decide the name of another attribute?
-Olivier
Edited by olivierth - Aug. 20, 2020 15:09:34
hello this might help you and it should be an interesting reading regarding performance
https://www.sidefx.com/forum/topic/68088/ [www.sidefx.com]
Ah! Found a way.
I used the setpointattrib fonction:
setpointattrib(0, myAttName, @ptnum, @Cd.r, "set");
Edited by olivierth - Aug. 20, 2020 15:12:03
olivierth
Ah! Found a way.
A better way is to use the bindings tab.
Leave the code as:
@myattrib = @Cd.r;
And then in the bindings tab, add a binding from myattrib to your attribute name. One is the vex name the other is the attribute name. That way you can change the attribute name, or even put nothing!, to change the name of the attribute created.
