TOP Task Timer
1684 2 1- Follyx
- 237 posts
- BabaJ
- 2024 posts
Generally once cooking starts your at the ‘OS’ level where the cpu is engaged, so you can't really stop at that point.
With exception, because if you try pressing ESC(or even spamming ESC in a small number of cases), you might have some luck in the OS picking up that ESC interupt and stop the whole cooking process. But it really depends on what's going in the specific cook process/s involved that is engaging the CPU.(Some ‘cooks’ may involve ‘more than one process’ where the CPU is fully engaged and have gaps in which the OS is able to process the ESC.
Otherwise you just might be stuck with a very long cook if you done something like in vex in which you unintentionaly did something in your code that results in a very long ‘runoff’ process, which the only alternative left if you want to break is to close the file with the Task Manager.
However, judging by your posts title, you probably mean something else? Like maybe stopping between TOP ‘tasks’?
Perhaps if that's is the case, keep your eyes peeled on your post for someone who has worked with TOPs more than I and understands what your after.
Edited by BabaJ - Aug. 29, 2020 09:44:47
- Follyx
- 237 posts
