I was just testing some super simple attrib transfer stuff using VEX point cloud stuff. So, in my “file input” filed of the pcopen vop, I have the op the following op syntax:
opobj/test/mygeo
Which doesn't work for me…
but, it seems to work perfectly when I something like:
opbj/test/mygeo
Is this intended design? Or is it some inconsistencies/bugs?
H8.1.903 on XP
Much thanks!
A
op syntax weirdness?
2936 3 1- EigenAlex
- 639 posts
- Simon
- 2199 posts
- EigenAlex
- 639 posts
Hmm… I was thinking more in term as a path – this /obj/blah/blah seems to make a bit more sense to me than obj/blah/blah… So that in my vex parameter I'd can just put something like: op:`opinputpath(“.”, 1)` as opposed to op:`substr(…)`.
Anyways, either way is fine by me as long as it ultimately worked and doesn't hinder what I wanted to do. Just wanted to point it out if it was unintended design.
Thanks,
A.
Thanks,
A.
- Simon
- 2199 posts
Oops, I miss read your mail. ops:
I thought you were saying “/obj” works and “obj/” doesn't
Then i agree that is weird.
I've always used `opinputpath(“.”,0)`
which returns the full path, so i assumed the “/obj” would be the working version, if you echo out `opinputpath(“.”,0)` you get “/obj….”
so that doesn't add up with the “obj/” being the working version when you write it by hand.
