I have two different DOP Objects (RBD Packed) and I want to source Geometry into just one of the objects, not both. I am using the popsource node which by default sources to both of my objects.
(Using just one object is not an option for now)
Any tips?
POP Sourcing into specific DOP object
2610 3 1- alancompany
- 15 posts
- cwhite
- 725 posts
- alancompany
- 15 posts
- cwhite
- 725 posts
If you have the daily 18.5 builds, the Enable Solver now has an Enable Objects parameter that lets you easily enable the solver for only a specific object or set of objects.
Previously, the Enable Solver approach required adding some subdata to “tag” the object and then using the Enable Data parameter, kind of similar to the Switch Solver / Switch Value workflow
