Hi!
I have a simple setup where I use a carve node to get a primitive for each segment of a curve (using the Cut at all internal U Breakpoints option). The issue is that in some cases (depending on the curve used as input) it doesn't recognize a point and jump the primitive that goes there and I can't figure out why.
I add an example file where in this case the carve is jumping the primitive that goes between point 14 and point 15.
Bug on Carve node
1880 4 0- Sabrina_p
- 3 posts
- vusta
- 555 posts
- mestela
- 1716 posts
- Sabrina_p
- 3 posts
- vusta
- 555 posts
