Hi there,
Is there any “by-pass” flag or button for the VEX builder's node?
Thank you for your attention!
"by-pass" flag
3185 2 1- brucelay
- 313 posts
- brucelay
- 313 posts
- pbowmar
- 7025 posts
It's not really possible in VOPs because there is no standard “piece of data” flowing from one VOP to the next. For example, if you have a Parameter node that defines colour, which feeds into a Luminance node, which then outputs a float, and then goes into a Displace along Normal node. If you bypass the Luminance node, everything breaks because now you're trying to feed a Colour (vector) into a float, which doesn't work. In SOPs or POPs you're feeding the same data from one node to the next so bypass makes more sense.
Peter B
Peter B
