I am very new to Houdini, so apologies if some of the nomenclature is incorrect.
I work in a group that generates A LOT of content and created a Hip file that formats the content the way I need, (basically scales it, clips some stuff, and converts it to an FBX and saves it with the correct name in the correct folder). Problem is that I have to manually change the input node in my Hip file each time I need to run a new piece of content thru it.
Is there a way to tell Houdini to run each piece of content in a folder thru my existing Hip file?
How to automatically format & convert a folder of content
1759 3 0- Zach_oo1
- 2 posts
- mestela
- 1737 posts
- Zach_oo1
- 2 posts
mestela
Tops.
@Mestela,
I have found the Tops FilePattern node but cant figure out how to pass those files into my Geometry object that has my workflow i need the files to go thru, could you point me point me in a clearer direction?
(also thanks for the link to your documentation, that helped alot, and I'm sure that this one hang-up here is probably a stupid error on my part
- tamte
- 8538 posts
