Copy to Points not oriented based on normal
   898   2   1
Greetings,
I would like to perform a copy-to-points by using a resampled curve. I've implemented polyframe so each point will have it's normal value based on its orientation. It looks fine when I visualize the normal. However, the box copied along the curve is not oriented properly as in the image below.
I've manually checked the value and it seems right (with @N.z always set to 0). The image below shows the network and spreadsheet of the attributes.
Any idea why I got this behaviour? Kinda new to Houdini, sorry for this very basic question. I've googled around and even follow a few tutorials, but didn't work.
Thank you in advance.
one vector is not enough for orientation (you need at least 2 vectors, which are not on one line). You can set @up vector for Normal Name in polyframe for example, or use the orientation along curve node, which is much better for stable result.
curve_orientation_copy.hipnc (86.1 KB)
Aizatulin
This works. Thanks a lot
