How to flatten a Ngon base on average height of each points
1849 4 0- martiancomeon
- 3 posts
- Aizatulin
- 472 posts
it seems, that all roofs are represented by one primitive, which is part of the "extrudeFront" group. You can loop over the primpoints for each prim, take the average and write the y-component back to original points. This should be doing, what you already described.
Check the modification of your file.
Edited by Aizatulin - Jan. 14, 2021 13:01:04
- aireverie
- 3 posts
maybe you can do this:
running in point mode
just put the primitives you want to flatten in group of the vex snippet
For lots of buildings i think this will be faster:
Run in primitive mode:
gives you 3 modes: avg, max, min
vector min; vector max; getbbox(min,max); @P.`chs("axis")` = max.y;
//aireverie n-gon flatten int a[] = primpoints(0, @primnum); vector b[]; float c[]; vector newP; for(int i=0; i<len(a); i++) { newP = point(0, "P", a[i]); push(b, newP); push(c, newP.y); } float min = min(c); float max = max(c); float avg = avg(c); for(int i=0; i<len(b); i++) { newP = b[i]; if(chi("mode")==0){ newP.y = min; setpointattrib(0, "P", a[i], newP); } else if(chi("mode")==1) { newP.y = avg; setpointattrib(0, "P", a[i], newP); } else if(chi("mode")==2) { newP.y = max; setpointattrib(0, "P", a[i], newP); } }
Edited by aireverie - Jan. 14, 2021 13:10:33
- martiancomeon
- 3 posts
AizatulinThank you so much for you answer!! I have figured it out. Thank you again!
- martiancomeon
- 3 posts
aireverieThank you very much!!your are so nice! I have learned a lot, Thank you!
maybe you can do this:vector min; vector max; getbbox(min,max); @P.`chs("axis")` = max.y;
gives you 3 modes: avg, max, min//aireverie n-gon flatten int a[] = primpoints(0, @primnum); vector b[]; float c[]; vector newP; for(int i=0; i<len(a); i++) { newP = point(0, "P", a[i]); push(b, newP); push(c, newP.y); } float min = min(c); float max = max(c); float avg = avg(c); for(int i=0; i<len(b); i++) { newP = b[i]; if(chi("mode")==0){ newP.y = min; setpointattrib(0, "P", a[i], newP); } else if(chi("mode")==1) { newP.y = avg; setpointattrib(0, "P", a[i], newP); } else if(chi("mode")==2) { newP.y = max; setpointattrib(0, "P", a[i], newP); } }
