fused curve to polygon?
2270 6 0- olivierth
- 1004 posts
- Aizatulin
- 474 posts
- Hans Palacios
- 57 posts
- PaQ WaK
- 89 posts
Salut Olivier,
You first need to find a way to close one side with a curve (the red curve in this example), maybe you will need a bit of vex, like starting from the first valence 1 point, and find the closest next valence 1 point, and build a polyline with those two points. But maybe you can find an easier way to isolate this 2 points, I don`t know the setup.
After that, fuse everything, polypath to create a single ordered curve, and the end sop to close it as polygon.
Edited by PaQ WaK - Jan. 14, 2021 14:53:12
Gameloft
- PaQ WaK
- 89 posts
- Aizatulin
- 474 posts
- olivierth
- 1004 posts
