Hello guys,
i am trying to create an alembic file of a mesh, i would like to include several elements, the final mesh will not be animated per se, but used as a scatter element ( from one single mesh to a certain amount of them all togheter).
the structure of the mesh is the following:
Main mesh which have been merged from different parts like so:
https://imgur.com/Qr7ofTP [imgur.com]
inside the main vial i have this structure which include, the main mesh and the dust/fibers like so:
https://imgur.com/jEfSgdv [imgur.com]
i forgot to mention it could be a redshift proxy too, but i can't find any info on how to do it.
is it possible to export the mesh with the fibers/dust and the shaders in alembic format? and if yes how?
thank you
Packing Mesh + shaders in Alembic
2763 4 2- hidalgo884
- 15 posts
- Berk_Erdag
- 86 posts
- hidalgo884
- 15 posts
- Berk_Erdag
- 86 posts
I think you can give Entagma's tutorial a try. https://www.youtube.com/watch?v=1h15stU-TaE [www.youtube.com]
It is about exporting from Houdini to Blender with alembic but should work for your case as well. (First 4 minutes might even be enough)
You're welcome and hopefully this'll solve your issues.
- tamte
- 8535 posts
hidalgo884For something this complex if you want to have it self contained rs proxy sounds easier unless it's not flexible enough for your needs
https://docs.redshift3d.com/display/RSDOCS/Intro+to+Proxies?product=houdini [docs.redshift3d.com]
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
