Tell me please, why does VOP: Ramp Parametr node not work?
What's wrong with this houdini?
978 2 2- Renji_kan
- 23 posts
- evanrudefx
- 208 posts
- Renji_kan
- 23 posts
ejr32123
you need to adjust it on the attribute vop node, not the ramp on the inside. Is sort of "promotes" it to the attrib vop so you don't have to dive in to change it. so just go up one level and select the attribute vop and the ramp will be there
Thank you! It works.
But, why did they do that, I don’t understand.
If the parameters can only be changed in their "geometry context" from attribvop node, why then did they make these twists inside the Ramp Parametr node. This is strange, if not silly.
