Before I send this in as a bug, anyone know why this graft node changes the position of the lights?
(In Red colored lopnet network node.)
Graft Node changes light positions
1851 3 3- BabaJ
- 2038 posts
- toadstorm
- 359 posts
I'm still figuring all this USD stuff out myself, but I believe the issue is that the default Graft settings are trying to parent your /lights primitive from merge1 to /`opinput(".", @input)`, which is evaluating to /Light_CornerPt_3. That object has its own transform, and your lights are now inheriting it. If you change the Primitive Path to something else, like /lights, this will import your lights to the right location. However, because you're grafting and not sublayering or merging, that will entirely overwrite the /lights primitive from your other branch. Grafting is a referencing operation, and what you likely want is sublayering so that you combine any unique data underneath each branch. A Merge LOP is essentially a sublayering option for in-memory primitives like what you have here, which is why it works the way you'd expect.
tl;dr keep your scene graph tree open at all times and sublayer/merge if you want to combine things under the same xform
Edited by toadstorm - June 17, 2021 14:56:00
- BabaJ
- 2038 posts
- robp_sidefx
- 451 posts
