Middle click won't work after openning scene in Houdini
   823   0   1
Hello
I am runnig Houdini 18.5.596 and Houdini Engine V2 in Unreal.
Each time after openning scene in Houdini in Unreal Editor, middle mouse click won't work in the scene file that opened, the node info won't pop up. I have to close the scene and open it again to get the middle click working.
It's annoying and time consuming to do that over and over again. It's there anyway to fix that?
This is the log printed in Houdini Console after middle clicking a node:
Thrift: Wed Jul 21 16:51:01 2021 Client connected.
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraph.py", line 166, in handleEventCoroutine
    pending_actions)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraph.py", line 1251, in handleEvent
    uievent.editor, output_index)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraphui.py", line 966, in createInfoWindow
    force_cook, output_index)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraphui.py", line 441, in display
    self.update(node, pinnable, recook, output_index)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraphui.py", line 494, in update
    verbose=verbose, debug=debug)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraphui.py", line 169, in update
    templatefile, showall=self.showall, **kwargs
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\baseinfowindow.py", line 289, in update
    template = theTemplates.get_template(templatefile)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\mako\lookup.py", line 85, in get_template
    return self.__load(srcfile, uri)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\mako\lookup.py", line 127, in __load
    self.__collection[uri] = Template(uri=uri, filename=posixpath.normpath(filename), lookup=self, module_filename=(self.modulename_callable is not None and self.modulename_callable(filename, uri) or None), **self.template_args)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\mako\template.py", line 93, in __init__
    (code, module) = _compile_text(self, file(filename).read(), filename)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\mako\template.py", line 265, in _compile_text
    exec code in module.__dict__, module.__dict__
  File "basic_mako", line 1, in <module>
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\mako\cache.py", line 4, in <module>
    from beaker import cache
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\beaker\cache.py", line 10, in <module>
    import pkg_resources
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\pkg_resources.py", line 2594, in <module>
    _declare_state('object', working_set = WorkingSet())
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\pkg_resources.py", line 425, in __init__
    self.add_entry(entry)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\pkg_resources.py", line 440, in add_entry
    for dist in find_distributions(entry, True):
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python27\lib\site-packages\pkg_resources.py", line 1700, in find_on_path
    for entry in os.listdir(path_item):
WindowsError: [Error 0] : 'c:\\users\\bailetang\\appdata\\local\\temp\\*.*'
    pending_actions)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraph.py", line 1210, in handleEvent
    return handler.handleEvent(uievent, pending_actions)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraph.py", line 1116, in handleEvent
    uievent.editor)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python2.7libs\nodegraphui.py", line 1006, in toggleInfoWindow
    force_cook, editor, output_index)
WindowsError: [Error 0] : 'c:\\users\\******\\appdata\\local\\temp\\*.*'
Edited by pilotdon - July 26, 2021 02:33:52
