We have next situation- topology of an asset and a lot of static data saved to layer with rest pose. We import them at SOP level - then spool back with another file, which collect changes made in sop - as example - get static posed aaset, then apply point deformations- then save everything as layer. Everything works fine, except forced first time sampling of almost everything, which doesn’t changed, except may be some topological data, if we turn on corresponding switch in sop import lop.
If we wish to “mute” overriding other attributes- like uv etc. - which way should we point do not pay in this overriding layer any attention to them?
Thank you
