HI,
I want to export fbx files in a for loop and managed to use the detail "iteration" for naming the files. However, i want to use the Prims name attribute that I promoted to "detail" there instead. I used the expression similar to what i did for the iterations:
detail("../attribpromote /","name")
but this does not work. Is there something wrong with the expression and/or is there a better way to use a prims name attribute as file name for the export? Thanks a lot
