Unrecognized escape sequence in HEU_HoudiniVersion.cs
   2069   2   0
Hello
Just upgraded houdini engine plugin to 3.7.1 with Houdini 18.5.696
Project is no longer building on windows and mac. Error with unrecognized escape sequence in the HEU_HoudiniVersion.cs:
ERRORS:
[Unity] Assets/Plugins/HoudiniEngineUnity/Scripts/HEU_HoudiniVersion.cs(72,63): error CS1009: Unrecognized escape sequence
[Unity] Assets/Plugins/HoudiniEngineUnity/Scripts/HEU_HoudiniVersion.cs(72,70): error CS1009: Unrecognized escape sequence
[Unity] Assets/Plugins/HoudiniEngineUnity/Scripts/HEU_HoudiniVersion.cs(72,75): error CS1009: Unrecognized escape sequence
! build of 'default-windows-desktop-64-bit' failed. exit
[Unity] Initialize engine version: 2021.1.20f1 (be552157821d)
[Unity] warning: Using obsolete custom response file 'mcs.rsp'. Please use 'csc.rsp' instead.
publishing finished successfully.
the line HEU_HoudiniVersion.cs(72):
               public const string HOUDINI_INSTALL_PATH = "C:\cygwin\home\prisms/Library/Application Support/Steam/steamapps/common/Houdini Indie";
the entire HEU_HoudiniVersion.cs:
* Copyright (c) <2020> Side Effects Software Inc.
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* Produced by:
*      Side Effects Software Inc
*      123 Front Street West, Suite 1401
*      Toronto, Ontario
*      Canada   M5J 2M2
*      416-504-9876
// WARNING! This file is GENERATED by Unity_v2_generate_version.py.
// DO NOT modify manually or commit to the repository!
namespace HoudiniEngineUnity
        public class HEU_HoudiniVersion
                public const int HOUDINI_MAJOR			= 18;
                public const int HOUDINI_MINOR			= 5;
                public const int HOUDINI_BUILD			= 696;
                public const int HOUDINI_PATCH			= 0;
                public const string HOUDINI_VERSION_STRING = "18.5.696";
                public const int HOUDINI_ENGINE_MAJOR	= 3;
                public const int HOUDINI_ENGINE_MINOR	= 7;
                public const int HOUDINI_ENGINE_API		= 1;
                public const int UNITY_PLUGIN_VERSION	= 2;
#if UNITY_EDITOR_WIN || (!UNITY_EDITOR && UNITY_STANDALONE_WIN)
                public const string HAPI_BIN_PATH		= "/bin";
                #if UNITY_EDITOR_64 || UNITY_64
                        public const string HAPI_LIBRARY	= "libHAPIL";
                        public const string HARC_LIBRARY        = "libHARC";
                #else
                        public const string HAPI_LIBRARY	= "libHARC32";
                        public const string HARC_LIBRARY        = "libHARC32";
                #endif // UNITY_EDITOR_64
                public const string SIDEFX_SOFTWARE_REGISTRY = "SOFTWARE\\WOW6432Node\\Side Effects Software\\";
#elif UNITY_EDITOR_OSX || (!UNITY_EDITOR && UNITY_STANDALONE_OSX)
                public const string HOUDINI_FRAMEWORKS_PATH = "/Frameworks/Houdini.framework/Versions/Current";
                public const string HAPI_BIN_PATH		= HOUDINI_FRAMEWORKS_PATH + "/Resources/bin";
                public const string HAPI_LIBRARY_PATH		= HOUDINI_FRAMEWORKS_PATH + "/Libraries";
                        public const string HAPI_LIBRARY	= HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHAPIL.dylib";
                        public const string HARC_LIBRARY        = HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHARC.dylib";
                #else
                        public const string HAPI_LIBRARY	= HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHARC32.dylib";
                        public const string HARC_LIBRARY        = HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHARC32.dylib";
#elif UNITY_EDITOR_LINUX || (!UNITY_EDITOR && UNITY_STANDALONE_LINUX)
                public const string HOUDINI_INSTALL_PATH	= "/opt/hfs" + HOUDINI_VERSION_STRING;
                public const string HAPI_LIBRARY_PATH		= "/dsolib";
                public const string HAPI_SERVER				= HOUDINI_INSTALL_PATH + HAPI_BIN_PATH + "/HARS";
                public const string HAPI_LIBRARY			= HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHAPIL.so";
                public const string HARC_LIBRARY                        = HOUDINI_INSTALL_PATH + HAPI_LIBRARY_PATH + "/libHARC.so";
#else
                // Unsupported platform: cannot be empty but its ok if not found.
#endif
}	// HoudiniEngineUnity
How Can I fix this?
Turns out this was an issue with Unity Cloud Build. The issue is now fixed.
Edited by armitageshanks - Oct. 19, 2021 09:42:34
Alright, this issue is back once again.
Houdini engine plugin 4.2.8
Mix of forward slashes and back slashes apearing in HEU_HoudiniVersion.cs
This causes Unity Cloud Build to fail.
Build still builds locally on my windows machine.
I have spoken to unity support and they think it's not their issue.
Edited by armitageshanks - Jan. 18, 2022 18:33:50
