Particle noise based on age
3205 6 1- Stannojj
- 3 posts
- tamte
- 8539 posts
- Soothsayer
- 858 posts
- eikonoklastes
- 331 posts
Normalized age is available out of the box as
@nage
. You can access it directly in a Wrangle, but Houdini hides the living hell out of it from everywhere else, so it's not accessible in dropdown lists for nodes like Attribute Remap, for example. You have to explicitly assign a float attribute to @nage
Edited by eikonoklastes - Oct. 17, 2021 04:19:33
- tamte
- 8539 posts
eikonoklastesit's not really hidden, it's clearly mentioned in docs [www.sidefx.com]
Normalized age is available out of the box as@nage
. You can access it directly in a Wrangle, but Houdini hides the living hell out of it from everywhere else, so it's not accessible in dropdown lists for nodes like Attribute Remap, for example. You have to explicitly assign a float attribute to@nage
however it's a double edged sword, as it still requires @age and @life to be present to be able to return correct value, so it's really mostly valid on geo coming from particle sim as lonf as @age and @life are still present, so it would be really confusing to expose it in dropdowns as if it was a real attribute
but for its confusing nature of not being a real attribute I'd prefer it didn't exist
Edited by tamte - Oct. 17, 2021 04:35:30
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- eikonoklastes
- 331 posts
tamteHidden in the UI is what I meant, to the extent where even if you explicitly type 'nage' in the attribute field, Houdini will not use it, but will happily use a float attribute that you have previously assigned to @nage.
As far as validity goes, if either @age or @life are not present, you can't manually calculate normalised age anyway, so that shouldn't affect @nage's usage.
Edited by eikonoklastes - Oct. 17, 2021 04:44:02
- tamte
- 8539 posts
eikonoklastes
what I meant is that @nage is not an attribute it's purely a made up shortcut to return @age/@life if they exist
but it will not show up in the UI dropdowns as it is not an attribute, same way @ptnum will not show up
@nage is really an odd one out which makes it confusing unless you know it's only and inplicit attribute computed on the fly from real attributes and fed to CVEX shader, you can't really use it as a real attribute in most SOP nodes as it doesnt really exist, unless you create a real attribute called @nage, but then it will make it even more confusing as suddenly @nage will not represent normalized age automatically computed from @age/@life anymore, but using your assigned value and all wrangles trying to use it will produce warning
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
