I'm facing an issue where I'm unable to used GasVorticleForces microsolver with a Pyrosolver. After plenty of testing I realized all the time it was working either on online docs or from workmates, it was using a SmokeSolver and not a PyroSolver.
Is there a world where this microsolver is never going be able to work with PyroSolver?
I always thought that PyroSolver was basically an improvement of the SmokeSolver being more complex with added features, so I assumed that whatever works with Pyro should work with SmokeSolver right?
Maybe it's not the case after all?
If it's not that, maybe the method to source it, is different when using a pyrosolver compared to using a smokesolver since it is working when I do how I did with the smokesolver (Applydata into gasvorticlegeometry, sourcing points with @mag, @pscale and @up)
Thank you for your time and help.
Thomas
GasVorticleForces not working with PyroSolver ?
529 0 0- Thomas_FX
- 12 posts
