Isolated vex code (not material) in Karma
1883 3 0- element33
- 74 posts
I watched the "Beautiful Game" tutorial on Vex and Karma (04). I understand that Vex materials can't be used in Karma. Is it just materials or any inclusion of any Vex code? I have an existing Vex displacement shader. I can isolate the part of the Vex code that computes displacement. Right now, there's no way to have Karma evaluate this Vex code to compute a value, correct? All I can do is render a displacement map from the Vex shader and pass this on to MaterialX as a texture, yes?
Edited by element33 - Nov. 28, 2021 04:54:31
- jerry7
- 620 posts
- element33
- 74 posts
- jsmack
- 7737 posts
element33
OK, thanks. Do you know per chance: can Redshift render Vex code on GPU? Or is there currently no GPU renderer that can do Vex displacement?
VEX is the native Houdini/Mantra shading language. No third party software can use VEX shader code. Karma CPU can also use VEX shaders because it is mostly Mantra compatible.
