Labs Flipbook Texture doesn't render
   7808   6   1
I am stuck with this error message...
Error
Error rendering child: /out/pyro_smoker/pre_render
Warning
Python error: Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 1321, in renderAndExport
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 1109, in renderAll
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 1097, in renderAll
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 566, in renderFinalColor
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 554, in renderFinalColor
File "labs::Driver/flipbook_textures::1.0, PythonModule", line 483, in setColorSpace
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.561/houdini/python3.7libs\hou.py", line 74509, in setOCIODisplayView
return _hou.SceneViewer_setOCIODisplayView(self, display, view)
hou.OperationFailed: The attempted operation failed.
Invalid display or view name
any suggestions on what might be the problem?
Edited by chf - March 22, 2022 13:20:09
chf
Error
Warning
Can you go to Houdini Text Port and type
echo $OCIO
? What result do you get?
Mai Ao
Senior Technical Lead of SideFX Labs
youtube.com/@notverydarkmagic
/ -> echo $OCIO
C:/Users/Fasching/Documents/houdini19.0/SideFXLabs/19.0.566/SideFXLabs19.0/misc/ocio/aces_config.ocio
I changed it via "Edit - Color Settings" to a different OCIO Folder on my disk and now it works.
Seems it didn't like the Labs OCIO Setting.
What directory did you change it to? I'm running into the exact same thing on Build 568 (of Houdini and Labs), changed my OCIO directory to "C:\Users\(user_name)\Documents\OpenColorIO-Configs-feature-aces-1.2-config\aces_1.2" and got the same error.
Edited by AramG - March 25, 2022 17:57:24
Aram Granger
Sr. VFX Artist
Respawn Entertainment
https://www.respawn.com [www.respawn.com]
AramG
I put it on C: directly and referenced it in the houdini.env file:
OCIO = "C:\OpenColorIO\aces_1.0.3\config.ocio"
this seems to have done it
Thank you, that helped me! I had that variable in the windows environment variables and it was getting ignored every time I restarted Houdini.
Aram Granger
Sr. VFX Artist
