Hi!
I'm making a simple HDA to copy a megascan mesh (brick wall) multiple time on X and have all meshes stacked perfectly. The goal is to end up with points containing the s@unreal_instance to end up with instances of that mesh.
Currently, I only have the Object Merge path exposed (and the number of copies). Yet, in Unreal, I can see one slot in my "Houdini Parameters" and one slot in "Houdini Output". When I test it out, I can see the top slot controls the distance between copies and the bottom slot controls what mesh I see in the viewport.
I only have the object merge path exposed. Why do I end up with 2 slots in Unreal?
-Olivier
one Object Merge path parameter exposed: Unreal has 2 slots?
1104 0 0- olivierth
- 1007 posts
