Hi all.
If I add an assign material inside and HDA where I have used restructureSceneGraph it can no longer see the material. The same happens to Prims as well so I cannot assign anything.
The Example HDA shows this. Now the annoying thing is I came across this before and Mark T said I need to change a few lines of code somewhere. I do actually have an old example working (uhassetouput2.0). But for the life of me, cannot remember where the heck I need to change the code. I have gone through all my posts but cannot find where I asked the question before.
Would anyone have come across this as well, and know where I need to alter the assign material code. I know it is possible but just cannot remember how or where.
Best. Mark
Edit: It's always the way. After hours of looking around, the minute I post, I figure it out. So assuming your assign material is called assignmaterial2
The answer is inside the HDA the Primitives (primpattern#)and Material Path (matspecpath# Action Button should read:
import loputils
loputils.selectPrimsInParm(kwargs, True, lopparmnode=kwargs.node('assignmaterial2'), allowinstanceproxies=True)
Mark
LOPS: assignMaterial not seeing material or prims inside HDA
803 0 1- Mark Wallman
- 644 posts
