I'm starting to learn Houdini and I have couple of questions.
1 - When you do your Lookdev and you are still tweaking your Textures, how do you do to flush the texture memory, so Textures can be overwritten with the latest update and render properly ?
2 - I don't see any ACES options anywhere. Does it mean by default ACES isn't supported inside Houdini ?
3 - Can you isolate a selected node to visualize the result ? Let's say I'm using a colorCorrection after a Texture node and I'd like to see the result of the colorCorrection with a flat render.
4 - Can you control the amount of subdivision during the render per mesh ?
Thanks for your time
Houdini/Karma LookDev questions
939 1 0- FloatingRock
- 1 posts
- olivierth
- 1004 posts
